Hello i enabled incremental backups, i added this code to crontab:
# DAILY backup for user (03:00 every day)
0 3 * * * sudo /usr/local/hestia/bin/v-backup-user user
# WEEKLY backup for admin (Sunday 01:00)
0 1 * * 0 sudo /usr/local/hestia/bin/v-backup-user admin
# HOURLY incremental backup via Restic
0 * * * * /usr/local/hestia/bin/v-backup-users-restic
In Gui when i go to incremental backups i see files like, 04ba3cc6, 459238d4, 08bb4bb4
But how can i restore them via ssh?
sahsanu
2
Those are the snapshots.
v-restore-user-full-restic USER SNAPSHOT KEY
Note: I’ve never used incremental backups managed by Hestia
Thanks, what is key where can i find it? because i never encountered it, i just enabled incrementla and that is
sahsanu
4
The key is in this file: /usr/local/hestia/data/users/YOUR_USER/restic.conf
cat /usr/local/hestia/data/users/YOUR_USER/restic.conf
bakkar
5
I previosuly had this question (how to access my restic repo from anywhere) since my personal PC is windows i need a way to access it,
check this docker image tool which can help you extract the repo easily: GitHub - Eboubaker/hestia_ib_quick_restore: docker image with small script to restore hestia incremental backup
hope that helps.
