How to run HestiaCP with Global SSL Offloading (pfSense + HAProxy)
Happy new year :partying_face:
I am looking for a way to configure my HestiaCP server to work behind a remote pfSense + HAProxy firewall that handles all SSL termination (SSL Offloading).
My Infrastructure:
  • Server: Ubuntu 22.04.5 LTS
  • HestiaCP: 1.9.4
  • DNS: Cloudflare (Proxied) pointing to pfSense WAN.
  • Traffic Router: pfSense with HAProxy listening on Port 443.
  • SSL Handling: HAProxy handles the Let’s Encrypt certificates (SSL Offloading).
  • Backend: HestiaCP (internal IP) receiving traffic from HAProxy on Port 443.
  • SSL Handling: HestiaCP handles the Let’s Encrypt certificates too
  • Volume: I have over 100 sites on this HestiaCP instance.
The Current Problem:
When I route traffic through HAProxy to HestiaCP on port 80, I get the “Too Many Redirects” error on sites.
For WordPress sites i have tried to edit wp-config.php
by adding this to it
// Fix for "Too Many Redirects" when using HAProxy SSL Offloading if (isset($_SERVER['HTTP_X_FORWARDED_PROTO']) && $_SERVER['HTTP_X_FORWARDED_PROTO'] === 'https') { $_SERVER['HTTPS'] = 'on'; }
sometimes it works sometimes doesn’t work.
I am looking for a Global Server-Side Fix so that HestiaCP/Nginx/Apache recognizes the X-Forwarded-Proto https header sent by my HAProxy and tells PHP/Sites that the connection is secure.
My Questions:
  1. Template Modification: Which Nginx/Apache templates should I modify in /usr/local/hestia/data/templates/web/ to ensure the X-Forwarded-Proto header is respected globally across all domains?
  2. Redirect Prevention: How can I globally disable Hestia’s internal HTTP->HTTPS redirects (for all existing and future sites) since the redirect should only be handled by the firewall/Cloudflare?
  3. PHP-FPM: Is it better to use a global auto_prepend_file in PHP-FPM to set $_SERVER['HTTPS'] = 'on' when the proxy header is present, or is there a native HestiaCP way to achieve this?
I want to avoid manual edits per domain. Any advice for a way to “Sync” Hestia with an external SSL proxy would be greatly appreciated!
HAProxy Configuration:
To ensure the backend (HestiaCP) receives the correct metadata, I have configured my HAProxy Frontend and Backend as follows:
  • Mode: http (Layer 7) to allow header manipulation.
  • SSL Offloading: HAProxy terminates the SSL and communicates with HestiaCP via its internal IP on Port 80.
  • Forced Headers (Backend Pass-thru): I have added the following directives to the backend configuration to signal the secure nature of the original request:
    Codefragment
    http-request set-header X-Forwarded-Proto https
    http-request set-header X-Forwarded-Port 443
    http-request set-header X-Real-IP %[src]
  • ACL Priority: I am using a Shared Frontend where specific Host-based ACLs (e.g., api.test.nl) are prioritized over broader web rules to ensure correct routing to different containers and the HestiaCP VM.
The Goal for the Hestia Side:
I need the HestiaCP Nginx/Apache stack to “trust” these headers globally. Specifically, when Hestia receives X-Forwarded-Proto: https on port 80, it should:
  1. Not trigger a 301 redirect to HTTPS.
  2. Pass the “HTTPS” status to PHP so that $_SERVER['HTTPS'] is evaluated as 'on', preventing WordPress from creating its own redirect loops.
Did you find a solution for this? This has been a hit-or-miss issue for me. I have a VPS and use Cloudflare for DNS and to handle SSL, but on some domains, it automatically triggers a ERR_TOO_MANY_REDIRECTS error as soon as I enable “Always use SSL” setting in Cloudflare.
yes i have fixed but can u give me some more details about your issue to help u out?
Definitely avoid this and instead write your own redirect rule that exempts the /.well-known/acme-challenge path.
