How to safely upgrade packages on RPI?
if run sudo apt update
it will create any problem with hestiacp packages?
Thank you,
Thank you,
That alone won’t cause issues. I do it all the time. You can run into trouble during updates if you replace your exisiting configuration files, so don’t do that unless you know it is safe.
okay, big brother.
thank you
