How do I set quotas for Users? I’m planning to limit users to use 5GB of the disk only. We’re now running out of storage on our server, and I would like to equally distribute the disk capacity to each User in the Control Panel.
Thank you.
Thank you.
Enable disk quotas
It might not work depending on your VM software if you use a VM
- normally quota should work just fine on debian, however you should enable it already during hestia install
Can I still install Quota Tools and Quota Kernel Module? I already installed Hestia CP on my Oracle Cloud VM. Will it require me to fresh install?
I’m using Ubuntu 22.04 server.
Run:
v-add-sys-quota
And see if it works
