I tried to add domain and set up own 2 nameserver, so that i can add domains via nameervers and not ip. How can i do it? It does not work unfortunately so easy
According to the docs, it should be easy: https://docs.hestiacp.com/admin_docs/server_management.html#how-to-setup-a-dns-cluster
New docs structure so the link will be:
https://docs.hestiacp.com/admin_docs/dns.html
i tried but failed. if you have 5 minut can i look at my panel please?
Have you tried my guide?
With that you should have absolutely no problem at all.
We can’t provide free support or debug on your system. But the dns cluster is working properly and has been tested multiple times. Should be a few lines if you follow the guide.
