How to setup SSL for IMAP/SMTP domains?
I’m on Ubuntu 20.04 with exim4 etc. The mail server is working, but I can’t seem to get the SSL stuff going. I’ve tried using my main hostname (i.e the domain where my Hestia CP is loaded, but on normal HTTP/SSL port), and that works fine for http/https. But I can’t get it to work. So a couple of questions:
  1. How can I get SSL for domains (i.e a hosted domain), which is setup using LE just fine for the web side - so actually work for emails as well? I could have sworn there used to be an option for it - but I can’t find it
  2. How can I get SSL setup for the main server domain (i.e what I have in /etc/hostname), so that Ic an also use that for connecting?
Andy
1.) edit mail domain, tick the ssl checkbox and generate one. then use mail.domain.tld for incoming and outgoing mails.
2.) set a proper a record for your hostname, then run v-add-letsencrypt-host
Thanks for the ridiculously fast reply :wink: When I try and set that up for the main domain (which is hosted on the “admin” account), I can’t actually add a mail domain to do that:
That side actually works fine already :slight_smile: (I can access https://north.xxx.com:9183 and also https://north.xxx.com both fine). The issue seems to be just when I do a SSL test
Cert Hostname DOES NOT VERIFY (mail.north.xxx.com != north.xxx.com | DNS:north.xxxcom)
		So email is encrypted but the host is not verified
I’m wondering if that has something to do with the MX record I had in the nameserver as Linode. It was set as mail.north.xxx.com). I’ve updated that so will see if that helps :slight_smile:
Andy
Create a new user, then in there create all you need
Ah I didn’t think about putting the mail domain under a new user… duh! (I assumed because the north.xxx.com domain was under “admin”, it would only allow a mail domain under that account)
I still can’t get this to work :frowning:
In /usr/local/hestia/ssl/mail I see the files correctly mail.brettinc.co.uk.key and .crt).
When trying to add in RoundCube:
So it seems to think its ok - until you go and add it:
It runs fine when I test it on https://www.checktls.com/TestReceiver:
I’m not sure what else to try :confused:
… check your settings: “Connection Security: None” can’t work…
Duh, me being an idiot! Must have missed that! Working now :slight_smile:
