Hello! I installed the Rclone program on the VPS to synchronize files from the /backup folder to the Google Drive cloud storage.
How do I set up a job in the CRON of the Hestia panel to execute a sync command?
I add the command to the CRON job:
/usr/bin/rclone sync --update --verbose --transfers 30 --checkers 8 --contimeout 60s --timeout 300s --retries 3 --low-level-retries 10 --stats 1s "/backup" "gdrive:HestiaCP"
but it doesn’t work. If I run the command via the commandline as root, then the sync works.
