Hello, need help with wp-cli commands.
I installed hestiacp, add user, enable SSH Access for the new user. Add command v-add-user-wp-cli for the user.
Login to ssh, and try command wp --info , but get answer -bash: wp: command not found
How i can use wp-cli commands?
eris
2
It is located in /home/user/.wp-cli/wp if I am right
If you want it. Globally available install it manually in /usr/bin
Yes, the new folder with .wp-cli exists, how i can use it?
system
Closed
4
