.htaccess RewriteRule doesn't work if URL matching an exists file
RewriteEngine On
RewriteRule ^(lib/images/image_exists.png)$ convert_webp.php?file=$1
# this not works, printing original image
https://example.com/lib/images/image_exists.png
# this is works, showing PHP script output
https://example.com/lib/images/image_not_exists.png
I tested on localhost(xampp) and another servers, and it’s works. But when I test on HestiaCP, it’s not works. What is problem? I think problem is NGINX proxy but I don’t know how it’s working. Can someone say a solution?
Nginx takes priority over apache2 for static files listed in:
Adjust a template (create a new Nginx template) or remove jpg, jpeg, png and gif from the Proxy extensions
Thank you very much, it’s works :slight_smile: Do HestiaCP have any donation method except Paypal and cryptocurrencies? My country has been blocked Paypal.
No, they are currently no other ways than crypto or paypal.
@ScIT I have some amount Litecoin. If you can add a option Litecoin, would be awesome.
