Htpasswd for Opencart directory and Nginx only (Solved)
Hi! I want to protect the admin panel login for cms opencart (located in /admin/).
I created .htpasswd in the /admin/ directory and made these settings for the template:
    location /admin/ {
    try_files $uri $uri/ =404;
    auth_basic "Password-protected Area";
    auth_basic_user_file %docroot%/admin/.htpasswd;
But when I go to the domain/admin link and log in, I just download the file config.php and I can’t log in to the opencart admin panel. I only use nginx without apache. What did I do wrong?)
%docroot% doesnt work in .htaccess, you need to write that one out.
Should be replaced by /home/user/web/domain/public.html
I saw similar settings for Apache on the forum, but I only use Nginx and specifically noted this. I tried to specify the full path, the result was the same.
The working solution is:
location ^~ /admin {
    location ~ .(php)$ {
        try_files $uri =404;
        fastcgi_pass %backend_lsnr%;
        include fastcgi_params;
        fastcgi_param SCRIPT_FILENAME $request_filename;
