Http3 enabled by default?
Me too, I’ve been using Hestia for over 2 years and haven’t had those issues either.
probably is there an issue / bug on default wordpress template on hestia?
Remove this directive.
Done, restarted nginx, same problem
Then the problem is WordPress, it’s the one doing the redirection and not getting the host. I’m using this template on my test WordPress site, and I can’t reproduce the issue. Everything works as expected on all pages, even when using HTTP/3.
/usr/local/hestia/data/templates/web/nginx/php-fpm/wordpress-http3.tpl
server {
        listen      %ip%:%web_port%;
        root        %docroot%;
        location = /favicon.ico {
                log_not_found off;
                access_log off;
        location = /robots.txt {
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        location = /xmlrpc.php {
                        deny all;
                        access_log off;
                        log_not_found off;
                        return 403;
        location / {
                        expires 30d;
                location ~* /(?:uploads|files)/.*.php$ {
                        deny all;
                        return 404;
                location ~ [^/]\.php(/|$) {
                        try_files $uri =404;
                        fastcgi_index index.php;
                        fastcgi_pass %backend_lsnr%;
                        if ($request_uri ~* "/wp-admin/|/wp-json/|wp-.*.php|xmlrpc.php|index.php|/store.*|/cart.*|/my-account.*|/checkout.*") {
                                set $no_cache 1;
                        if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in|woocommerce_items_in_cart|woocommerce_cart_hash|PHPSESSID") {
                                set $no_cache 1;
        location /error/ {
        location /vstats/ {
/usr/local/hestia/data/templates/web/nginx/php-fpm/wordpress-http3.stpl
server {
        listen      %ip%:%web_ssl_port% quic;
        listen      %ip%:%web_ssl_port% ssl;
        root        %sdocroot%;
#       ssl_stapling        on;
#       ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
        add_header Alt-Svc 'h3=":$server_port"; ma=86400';
                log_not_found off;
                access_log off;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
                        deny all;
                        access_log off;
                        log_not_found off;
                        return 403;
        location / {
                        expires 30d;
                        deny all;
                        return 404;
                                set $no_cache 1;
                                set $no_cache 1;
        location /error/ {
        location /vstats/ {
tried your template. same problem. I don’t understand! it’s weird…
take a look here, you’re more experienced than me:
Risolto - Nginx HTTP3 causa reindirizzamento invalido su WordPress | Plesk Forum
I can’t find /etc/nginx/fastcgi.conf
@sahsanu it works fine. I found the solution.
Adding fastcgi_param HTTP_HOST $host; into /etc/nginx/fastcgi__params
Thanks for sharing. I can’t reproduce it on my site because WordPress doesn’t do any redirection.
Could you please open an issue so I can create a PR to add it to next release?
Absolutely!
Created at [Bug] Redirect error on WordPress enabling NGINX HTTP3 · Issue #5184 · hestiacp/hestiacp
Tell me if I have to edit something, I never did it.
No, that’s enough, thanks.
Hestia doesn’t modify /etc/nginx/fastcgi_params, it’s the conf included by default in Nginx so I think it would be better to modify the WordPress templates.
Can I add fastcgi_param HTTP_HOST $host;directly into WordPress template?
Yes, you can.
I’ve created this PR:
If you want to test it, you can download the wordpress-http3 template. I’ve also added a script to automatically add reuseport if none of the sites are using it. If some site is already using it, the next domains will use only quic.
cd /usr/local/hestia/data/templates/web/nginx/php-fpm
curl -fsSLm10 https://raw.githubusercontent.com/sahsanu/hestiacp/bfceecb57bf9c6a9926e82631112662619f3e2ad/install/deb/templates/web/nginx/php-fpm/wordpress-http3.sh -O
chmod +x wordpress-http3.sh
curl -fsSLm10 https://raw.githubusercontent.com/sahsanu/hestiacp/bfceecb57bf9c6a9926e82631112662619f3e2ad/install/deb/templates/web/nginx/php-fpm/wordpress-http3.stpl -O
curl -fsSLm10 https://raw.githubusercontent.com/sahsanu/hestiacp/bfceecb57bf9c6a9926e82631112662619f3e2ad/install/deb/templates/web/nginx/php-fpm/wordpress-http3.tpl -O
Once all the files are downloaded, you can assign the wordpress-http3 template to your domains to test it.
I would appreciate it if you could test it.
I deleted the change made it into /etc/nginx/fastcgi_params, I reproduced the issue again, I deleted all templates http3 created by myself and add your change.
It works perfectly!
Hi everyone, as I remember we already did this, since then the directive lives in my template)
