Will there be support for http3? - Community Support / Web - Hestia Control Panel - Discourse
why Hestia doesn’t enable http3/quic by default?
To enable it, do I have to create a template for every type of domain? default, wordpress, etc etc….
thanks
What’s your domain so I can test it?
Did you create a firewall rule to allow access to port 443 protocol UDP ?
www.stefanofattori.it
Already opened 443 UDP port on Oracle Cloud
Did you restart nginx?
cat /etc/nginx/conf.d/domains/stefanofattori.it.ssl.conf
sahsanu:
Yes.
Default Web Domain Template
DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS
server {
listen 10.0.0.156:443 quic;
listen 10.0.0.156:443 ssl;
server_name stefanofattori.it www.stefanofattori.it;
root /home/stefano/web/stefanofattori.it/public_html;
access_log /var/log/nginx/domains/stefanofattori.it.log combined;
access_log /var/log/nginx/domains/stefanofattori.it.bytes bytes;
error_log /var/log/nginx/domains/stefanofattori.it.error.log error;
ssl_certificate /home/stefano/conf/web/stefanofattori.it/ssl/stefanofattori.it.pem;
ssl_certificate_key /home/stefano/conf/web/stefanofattori.it/ssl/stefanofattori.it.key;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
add_header Alt-Svc 'h3=":$server_port"; ma=86400';
include /home/stefano/conf/web/stefanofattori.it/nginx.hsts.conf*;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
log_not_found off;
access_log off;
deny all;
return 404;
location / {
expires 30d;
location ~* /(?:uploads|files)/.*.php$ {
deny all;
return 404;
location ~ [^/]\.php(/|$) {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass unix:/run/php/php8.4-fpm-stefanofattori.it.sock;
include /home/stefano/conf/web/stefanofattori.it/nginx.fastcgi_cache.conf*;
if ($request_uri ~* "/wp-admin/|/wp-json/|wp-.*.php|xmlrpc.php|index.php|/store.*|/cart.*|/my-account.*|/checkout.*") {
set $no_cache 1;
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in|woocommerce_items_in_cart|woocommerce_cart_hash|PHPSESSID") {
set $no_cache 1;
location /error/ {
alias /home/stefano/web/stefanofattori.it/document_errors/;
location /vstats/ {
alias /home/stefano/web/stefanofattori.it/stats/;
include /home/stefano/web/stefanofattori.it/stats/auth.conf*;
proxy_hide_header Upgrade;
include /home/stefano/conf/web/stefanofattori.it/nginx.ssl.conf_*;
You must also open it in the Hestia firewall:
v-add-firewall-rule ACCEPT 0.0.0.0/0 443 UDP HTTP3
I’m asking to open the UDP 443 port also in Hestia because it’s blocked:
❯ curl -vIL --user-agent 'sahsanu' --http3 www.stefanofattori.it 2>&1 | grep -A1 QUIC
* QUIC connect to 130.110.9.2 port 443 failed: Could not connect to server
* Failed to connect to www.stefanofattori.it port 443 after 62 ms: Could not connect to server
mmmh but I have the firewall disabled.
I opened it on Hestia and now it works fine.
But why I have to open port with the firewall iptabled disabled?
sahsanu
December 8, 2025, 2:47pm
11
Other processes could be adding rules to it. Show which are the iptables rules in your server:
iptables -S
So even if I disable iptables from Hestia, it could still be operational?
Thanks for the solution
Oh sorry just last question.. so I don’t have to use reuseport? Just quic?
sahsanu
December 8, 2025, 3:07pm
15
You should use reuseport only once in a server. For your other sites you should remove reuseport from the template. So you need two templates for your sites, one with quic reuseport and the other without reuseport
oh ok, actually I’m using only quic.. so I’ll create reuseport for the main site.
I realised I had a problem with http3, though…
Try navigating to www.stefanofattori.it in the subpages, then click on the home page or logo again, and a redirect problem occurs.
This does not happen when I revert to the http2 template.
sahsanu
December 8, 2025, 3:27pm
17
What I see is that redirection is not working:
❯ curl -IL --http3 www.stefanofattori.it
HTTP/1.1 301 Moved Permanently
Server: nginx
Date: Mon, 08 Dec 2025 15:21:16 GMT
Content-Type: text/html
Content-Length: 162
Connection: keep-alive
HTTP/3 301
server: nginx
date: Mon, 08 Dec 2025 15:21:16 GMT
content-type: text/html; charset=UTF-8
set-cookie: PHPSESSID=sen8m7g5ivojtu1bitkh9tc2uf; path=/
expires: Thu, 19 Nov 1981 08:52:00 GMT
cache-control: no-store, no-cache, must-revalidate
pragma: no-cache
x-redirect-by: WordPress
alt-svc: h3=":443"; ma=86400
strict-transport-security: max-age=31536000;
curl: (3) The redirect target URL could not be parsed: No host part in the URL
What are the contents of:
cat /home/stefano/conf/web/stefanofattori.it/nginx.hsts.conf
cat /home/stefano/conf/web/stefanofattori.it/nginx.ssl.conf_redirect
sahsanu
December 8, 2025, 3:30pm
18
Anyway, it looks like the problem is that WordPress isn’t able to determine the host when requests come through HTTP/3.
add_header Strict-Transport-Security “max-age=31536000;” always;
cat: /home/stefano/conf/web/stefanofattori.it/nginx.ssl.conf_redirect: No such file or directory
If I delete the cache it works for the first time, then if I navigate on subpages and I’ll come back to hompage I get redirect error.. only with http3 enabled
I never got this issue with WordPress on other hosts or panels
