strange problem. the site opens perfectly on http3 if you access it using ip6, but stubbornly remains on http2 if you leave only ip4.
in the config I tried different combinations and options that I found on Google:
server {
listen 82.202..:443 quic;# reuseport;
listen 82.202..:443 ssl;#listen [2a00:ab00:1103:*::*]:443 quic reuseport; #listen [2a00:ab00:1103:*::*]:443 ssl; http3 on; # http3_hq on; ??? quic_retry on; quic_gso on; # ssl_early_data on; already in the main config # required for browsers to direct them to quic port # from location / { add_header Alt-Svc 'h3-28=":443"; ma=604800'; add_header Alt-Svc 'h3=":443"; ma=2592000,h3-29=":443"; ma=2592000'; add_header x-quic 'h3'; add_header X-protocol $server_protocol always; server_name *.* www.*.*;
instead of asterisks - numbers and domains.
the essence of the problem: on IP6 everything is fine, in chrome you can immediately see h3. Doesn’t work on IP4.
I suspect that somewhere Hestia automatically does something for ip4, but I didn’t find anything
