Https for panel certificate renewal
The certificate for my hestiacp panel renewed on 2025/11/14 and my main site panel.xxxx.com loads in https but when I access the panel with my port panel.xxx.com:8913 it loads as http and it has the old ssl certificate.
Any suggestions how to fix?
Thanks!
If the user that has the web domain panel.example.com is admin, run this as root:
v-update-host-certificate admin panel.example.com
As always, thank you @sahsanu ! That did it.
