hi i have a problem with my domain.
I reinstalled the server today with debian 10
I can use my domain:
Do not go to https://domain.com = page not found.
But if I enter www.domain.com the page is found, what is the problem?
Did you enabled a valid ssl certificate? Do you have something in your webserver log for the related domain? Without additional informations, it is not possible to help you
has the ssl certificate of https://host.xxxxxx.de
please disable and then enable Lets encrypt
I think you have some results?
An error has occurred
Internal error code: 6e64401782d3b748babf475a523f91c30bb2844d
Where is the error now?
You withdrawed a lot of your post, no idea where the error is . We can’t do the debug for you, I just can say that you should check, if a valid cert is active, if you get something into the access log of the relevant domain if you visit it with and without ssl, probaly do a manual check if the ssl conf is present in /home/user/conf/web/… I just can confirm, that hestia is working well on Debian 10 without any troubles on SSL, even our demo system is based on it https://demo.hestiacp.com:8083.
