Trying to obtain a few files using wget from one of the domains hosted on hestiacp,
but when using wget, it just hangs…
I can wget any other website and obtain files,
but any files i place on a domain hosted with hestiacp is a no go to download the files with wget.
Any way to allow the use of wget for certain domains or sub domains?
Any help would be greatly appreciative
wget should work out of the box, there is no limitation in hestia or even a “block” feature. No idea why it hangs on your system.
I figured it out once you cleared up nothing is blocking on hestiacp.
Was a network route issue, and nothing to do with the hestiacp…
Thanks for the fast response…
Appreciate it.
system
Closed
4
