I have a recurring problem with let's Encrypt SSL
Hi guys.
I have a recurring problem with let’s Encrypt SSL.
It turns out that some hosts do not self-renew SSL certificates.
I have to SSH in and run:
v-update-letsencrypt-ssl-host
or even sometimes create it again
At the same time when that happens to me I find that even though the panel tells me that a domain is ok with SSL
When I call the website shows me:
So I have to access the panel uncheck the SSL and recreate it.
Is it possible that it is a hosting problem or is it HestiaCP’s problem? Mostly for complaining to the hosting or keep doing it by hand (much more often than I would like).
Well, I guess my problem is with the ISP because every time I do that process of reinstalling SSL the VPS is down and it doesn’t complete unless I reboot the “machine” from the ISP.
Yes, that’s right. Hestiacp works normally!
