Hi guys,
So like title says I made changes to .css but it does not take effect when I visit site when refresh page so doe nginx serve cache, I could not find how to clear cache of nginx ?
Hi @Vido
Take a look to this post:
Hey @sahsanu
Ok awsome but I need help since my setup is different. I’m using Nginx+Apache, the templates for my Nginx is here /usr/local/hestia/data/templates/web/nginx/ right ? But I’m getting a warning to not modify @hcp:/usr/local/hestia/data/templates/web/nginx$ cat default.tpl
and her is it
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://hestiacp.com/docs/server-administration/web-templates.html #
server {
listen %ip%:%proxy_port%;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
deny all;
return 404;
location / {
proxy_pass http://%ip%:%web_port%;
location ~* ^.+\.(%proxy_extensions%)$ {
try_files $uri @fallback;
root %docroot%;
expires max;
location @fallback {
location /error/ {
If you are using Nginx+Apache you should use the template located in the /usr/local/hestia/data/templates/web/nginx/ directory.
cd /usr/local/hestia/data/templates/web/nginx/
cp default.tpl newtemplate.tpl
cp default.stpl newtemplate.stpl
Do the needed changes to newtemplate.tpl and newtemplate.stpl and once done, edit your web domain to use the newtemplate.
@sahsanu my /usr/local/hestia/data/templates/web/nginx/default.tpl does not match yours
server {
deny all;
return 404;
location / {
root %docroot%;
expires max;
location /error/ {
Should I edit
deny all;
return 404;
I don’t use Apache but you could use something like this:
Note 1: In these examples we are removing caching, only for these extensions; htm, html, css, js (you can modify them to suit your needs).
Note 2: The extensions added, in this example; htm, html, css, js MUST be removed from the Proxy Extensions field:
newtemplate.tpl
server {
deny all;
return 404;
location ~* \.(htm|html|css|js)$ {
root %docroot%;
open_file_cache off;
proxy_cache off;
proxy_no_cache 1;
proxy_cache_bypass 1;
add_header Cache-Control "no-store, no-cache, must-revalidate, proxy-revalidate, max-age=0";
expires off;
add_header Pragma "no-cache";
etag off;
location / {
root %docroot%;
expires max;
location /error/ {
newtemplate.stpl
server {
listen %ip%:%proxy_ssl_port% ssl;
ssl_certificate %ssl_pem%;
#Commented out ssl_stapling directives due to Lets Encrypt ending OCSP support in 2025
#ssl_stapling on;
#ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
deny all;
return 404;
root %docroot%;
proxy_cache off;
proxy_no_cache 1;
expires off;
etag off;
location / {
root %sdocroot%;
expires max;
location /error/ {
proxy_hide_header Upgrade;
