Hello, maybe someone can help me here.
Following issue i would like to use a reverseproxy for my domain wich i have addet to hestia.
Lets say my domain is test.com my files will be located after adding it to hestia here:
/home/Forum/web/test.com/public_html
I did the reverseproxy setup like this on another ubuntu 22.04 server the reverse proxy is working but the big problem what i have is that my domain wich is pointed to the reverseproxy ip and not hestia backend shows me not the website wich is located here /home/Forum/web/test.com/public_html
It seems like i just see the index.html file wich is located on my hestia server here /var/www/html
Maybe someone can help me to fix the issue and setup the reverse proxy right to get a mirror for the right dictionary /home/Forum/web/test.com/public_html
sudo apt update
sudo apt upgrade
apt-get install nginx
unlink /etc/nginx/sites-enabled/default
nano /etc/nginx/sites-available/reverse-proxy.conf
server {
listen 80;
location / {
proxy_pass http://HESTIASERVERIP;
ln -s /etc/nginx/sites-available/reverse-proxy.conf /etc/nginx/sites-enabled/reverse-proxy.conf
service nginx configtest
service nginx restart
systemctl status nginx
