Hello guys, I want to replace the panel .domain .co with this panel .domain .shop, I need a code.
Via ssh
Via ssh
v-change-sys-hostname “newhostname”
You mean, put the code directly without root
You need to run as root or
sudo /usr/local/hestia/bin/v-change-sys-hostname “newhostname”
run as root…
Of course I did that but to no avail, same error
Could you please paste the output of the commands you are using and the system response?
I want to change the panel and activate SSL, old panel.domain.shop to panel.domain.co
how can I do that via ssh
