Imap dovecot problems
imap not working after sometime used. But after restarting dovecot, it working again good. then after some minutes, it not working again. connection are disconnected
378903 ExecReload=/usr/bin/doveadm reload
Please help me.
check dovecot log, without additional informations it will be impossible to help.
Warning: fd limit (ulimit -n) is lower than required under max. load (1048576 < 99999999), because of default_client_limit
Max open file limit
This method notw working, ubuntu 20.04
and also auto imap conenction beeing stop
3664509 ExecReload=/usr/bin/doveadm reload (code=exited, status=0/SUCCESS)
dovecot auto are running ExecReload
Please can you tell me why it are ExecReload
please help me. I have many server. all server same issues. dovecot’s being auto disconnected
After restart then gain worked 10 min then again not working
I need urgently fix it
