IMAP not working correctly. every 10 min restart Dovecot then work.
How I will fix it without everytime restart Dovecot
Please help me.
Please help me.
Check logs first …
master: Warning: service(imap-login): process_limit (100) reached, client connections are being dropped
I found this from log.
How can fix it and increase unlimited
Please help me
Edit file /etc/dovecot/conf.d/10-master.conf and add directive process_limit with the amount of processes you want to use (by default the limit is 100) to service imap-login.
For example, if you want to raise the limit to 200:
service imap-login {
inet_listener imap {
inet_listener imaps {
process_limit = 200
Don’t forget to restart dovecot after the change:
systemctl restart dovecot
