Imposible to use roundcube
In a 1.94 hestia instalation i have various mail accounts that work fine.
One mail account has a problem. I have a wordpres web. When accesisg roundcube, it opens the wordpress site not the webmail.fland.es, it opens fland.es
¿How can I solve it , or is it incompatible to use web and mail at the same hestia?
cat /etc/nginx/conf.d/domains/fland.es.ssl.conf
cat /etc/nginx/conf.d/domains/webmail.fland.es.ssl.conf
server {
listen      173.212.247.202:443 ssl;
server_name fland.es www.fland.es webmail.fland.es mail.fland.es;
error_log   /var/log/apache2/domains/fland.es.error.log error;
    ssl_certificate     /home/webmaster/conf/web/fland.es/ssl/fland.es.pem;
    ssl_certificate_key /home/webmaster/conf/web/fland.es/ssl/fland.es.key;
    ssl_stapling        on;
    ssl_stapling_verify on;
    # TLS 1.3 0-RTT anti-replay
    include /home/webmaster/conf/web/fland.es/nginx.hsts.conf*;
            deny all;
            return 404;
    location / {
            proxy_ssl_server_name on;
            proxy_ssl_name $host;
            proxy_pass https://173.212.247.202:8443;
            location ~* ^.+\.(css|htm|html|js|mjs|json|xml|apng|avif|bmp|cur|gif|ico|jfif|jpg|jpeg|pjp|pjpeg|png|svg|tif|tiff|webp|aac|caf|flac|m4a|midi|mp3|ogg|opus|wav|3gp|av1|avi|m4v|mkv|mov|mpg|mpeg|mp4|mp4v|webm|otf|ttf|woff|woff2|doc|docx|odf|odp|ods|odt|pdf|ppt|pptx|rtf|txt|xls|xlsx|7z|bz2|gz|rar|tar|tgz|zip|apk|appx|bin|dmg|exe|img|iso|jar|msi|webmanifest)$ {
                    try_files  $uri @fallback;
                    root       /home/webmaster/web/fland.es/public_html;
                    access_log /var/log/apache2/domains/fland.es.log combined;
                    access_log /var/log/apache2/domains/fland.es.bytes bytes;
                    expires    max;
    location @fallback {
    location /error/ {
            alias /home/webmaster/web/fland.es/document_errors/;
    proxy_hide_header Upgrade;
    include /home/webmaster/conf/web/fland.es/nginx.ssl.conf_*;
root@hestiacp-02:\~#
root@hestiacp-02:~# cat /etc/nginx/conf.d/domains/webmail.fland.es.ssl.conf
cat: /etc/nginx/conf.d/domains/webmail.fland.es.ssl.conf: No such file or directory
root@hestiacp-02:~#
Thank you very much
The first thing you must do is to remove the aliases webmail.fland.es mail.fland.es from the web domain fland.es.
Once done, you must add a mail domain for fland.es, it will create the right conf for webmail and mail.
Thank you very much.
Now works fine
