Increase "load average" limit on manual backups
Can i increase the load average limit on manual backup and restore tasks?
For me is too dificult keep load average below 2, my servers always are on 3-4.
Thanks for your work!
Permanent option: Increase core count on your server …
This is the check
But if i change that file it will work for backups? Or only for restoring?
After searching a lot, I found a solution:
Edit the file:
/usr/local/hestia/func/main.sh
I switched this line:
BACKUP_LA_LIMIT=cat /proc/cpuinfo | grep processor | wc -l
For this
BACKUP_LA_LIMIT=30
Using the command v-backup-user username, the backup (zstd) was created in 0.5s.
Whoever has this problem, here is the solution.
Just what I was searching for!
Saved my day…
