I would like to install Nginx + PHP-FPM. At the moment, I’ve installed default servers in the VPS, so is there any way to override the default installation or should I format the instance and start over the installation process?
For Nginx + php-fpm this works fine
Many thanks @eris would you please tell me how I should run it? It looks like a bash file, but does the path exist in the hestia folder by default or do I have to upload the file you mention?
/usr/local/hestia/install/upgrade/manual/
And you should be able to find it…
Many thanks @eris. I got installed the script. Now, when I enable the FastCGI option, the nginx server failed to restart. I have WordPress site with a Redis server connected via the Object Cache Redis plugin. Seems that Redis with FactCGI don’t like each other, don’t they?
Should work fine
systemctl status nginx?
× nginx.service - nginx - high performance web server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2023-05-13 16:33:38 EEST; 7s ago
Docs: https://nginx.org/en/docs/
Process: 97938 ExecStart=/usr/sbin/nginx -c /etc/nginx/nginx.conf (code=exited, status=1/FAILURE)
CPU: 6ms
May 13 16:33:38 hcp.shavecode.codes systemd[1]: Starting nginx - high performance web server...
May 13 16:33:38 hcp.shavecode.codes nginx[97938]: nginx: [emerg] the shared memory zone "shavecode.codes" is already declared for a different use in>
May 13 16:33:38 hcp.shavecode.codes systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
May 13 16:33:38 hcp.shavecode.codes systemd[1]: nginx.service: Failed with result 'exit-code'.
May 13 16:33:38 hcp.shavecode.codes systemd[1]: Failed to start nginx - high performance web server.
@eris I’ve deleted /etc/nginx/conf.d/01_caching_pool.conf and the server restarts fine.
One last thing, I would like to use Smush Pro I’ve done a couple of research in the fourm and found I need to do some changes in wordpress.tpl in this section:
expires 30d;
Then the modified one would be like below:
location / {
# BEGIN SMUSH-WEBP
location ~* "wp-content\/(uploads\/)(.*\.(?:png|jpe?g))" {
add_header Vary Accept;
set $image_path $2;
if (-f "/home/Hussein/web/shavecode.codes/public_html/wp-content/smush-webp/disable_smush_webp") {
break;
if ($http_accept !~* "webp") {
break;
expires max;
try_files /wp-content/smush-webp/$image_path.webp $uri =404;
# END SMUSH-WEBP
I know I need to do the same change in wordpress.stpl too, but still no luck with followed the instructions.
