Installation error
I’m having this error in the installation, I don’t know how to solve it, I’m using arm
Updating currently installed packages, please wait... Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 8, in <module>
    from CommandNotFound.db.creator import DbCreator
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 12, in <module>
    import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
W: GPG error: http://ppa.launchpad.net/ondrej/apache2/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4F4EA0AAE5267A6C
E: The repository 'http://ppa.launchpad.net/ondrej/apache2/ubuntu focal InRelease' is not signed.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
NOTE: This process may take 10 to 15 minutes to complete, please wait...
E: Unable to locate package php8.2
E: Couldn't find any package by glob 'php8.2'
E: Couldn't find any package by regex 'php8.2'
E: Unable to locate package php8.2-apcu
E: Couldn't find any package by glob 'php8.2-apcu'
E: Couldn't find any package by regex 'php8.2-apcu'
E: Unable to locate package php8.2-bz2
E: Couldn't find any package by glob 'php8.2-bz2'
E: Couldn't find any package by regex 'php8.2-bz2'
E: Unable to locate package php8.2-cli
E: Couldn't find any package by glob 'php8.2-cli'
E: Couldn't find any package by regex 'php8.2-cli'
E: Unable to locate package php8.2-common
E: Couldn't find any package by glob 'php8.2-common'
E: Couldn't find any package by regex 'php8.2-common'
E: Unable to locate package php8.2-curl
E: Couldn't find any package by glob 'php8.2-curl'
E: Couldn't find any package by regex 'php8.2-curl'
E: Unable to locate package php8.2-gd
E: Couldn't find any package by glob 'php8.2-gd'
E: Couldn't find any package by regex 'php8.2-gd'
E: Unable to locate package php8.2-imagick
E: Couldn't find any package by glob 'php8.2-imagick'
E: Couldn't find any package by regex 'php8.2-imagick'
E: Unable to locate package php8.2-imap
E: Couldn't find any package by glob 'php8.2-imap'
E: Couldn't find any package by regex 'php8.2-imap'
E: Unable to locate package php8.2-intl
E: Couldn't find any package by glob 'php8.2-intl'
E: Couldn't find any package by regex 'php8.2-intl'
E: Unable to locate package php8.2-ldap
E: Couldn't find any package by glob 'php8.2-ldap'
E: Couldn't find any package by regex 'php8.2-ldap'
E: Unable to locate package php8.2-mbstring
E: Couldn't find any package by glob 'php8.2-mbstring'
E: Couldn't find any package by regex 'php8.2-mbstring'
E: Unable to locate package php8.2-mysql
E: Couldn't find any package by glob 'php8.2-mysql'
E: Couldn't find any package by regex 'php8.2-mysql'
E: Unable to locate package php8.2-opcache
E: Couldn't find any package by glob 'php8.2-opcache'
E: Couldn't find any package by regex 'php8.2-opcache'
E: Unable to locate package php8.2-pspell
E: Couldn't find any package by glob 'php8.2-pspell'
E: Couldn't find any package by regex 'php8.2-pspell'
E: Unable to locate package php8.2-readline
E: Couldn't find any package by glob 'php8.2-readline'
E: Couldn't find any package by regex 'php8.2-readline'
E: Unable to locate package php8.2-xml
E: Couldn't find any package by glob 'php8.2-xml'
E: Couldn't find any package by regex 'php8.2-xml'
E: Unable to locate package php8.2-zip
E: Couldn't find any package by glob 'php8.2-zip'
E: Couldn't find any package by regex 'php8.2-zip'
E: Unable to locate package php8.2-bcmath
E: Couldn't find any package by glob 'php8.2-bcmath'
E: Couldn't find any package by regex 'php8.2-bcmath'
E: Unable to locate package php8.2-fpm
E: Couldn't find any package by glob 'php8.2-fpm'
E: Couldn't find any package by regex 'php8.2-fpm'
E: Unable to locate package php8.2-soap
E: Couldn't find any package by glob 'php8.2-soap'
E: Couldn't find any package by regex 'php8.2-soap'
[ * ] Configuring system settings...
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/httpd-prerotate/*': No such file or directory
[ * ] Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
rm: cannot remove '/var/log/hestia': Is a directory
ln: failed to create symbolic link '/usr/local/hestia/log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/system.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/nginx-error.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/auth.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/backup.log': No such file or directory
chmod: cannot access '/usr/local/hestia/log': No such file or directory
chmod: cannot access '/var/log/hestia/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/dns/': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/firewall': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/api': No such file or directory
[ * ] Configuring OpenSSL to improve TLS performance...
[ * ] Generating default self-signed SSL certificate...
hst-install-ubuntu.sh: line 1353: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
[ * ] Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
[ * ] Enabling SFTP jail...
Error: can't enable sftp jail
Looks like there are some issues with http://ppa.launchpad.net
Wait for a moment and try again…
