Hello everyone.
I have been using HestiaCP on many servers for a long time and encountered installation problems for the first time.
Hestia Control Panel 1.8.11, Ubuntu 22, Serv 1CPU 5Ghz/2Gb/40Gb
The installation stops with a line in the log:
invoke-rc.d: policy-rc.d denied execution of restart.
The policy-rc.d file was not found in the system, it is missing. From the recommendations on the network, I tried to create it with the content: “#!/bin/sh\n exit 0”, but it did not help
I need help, please tell me ![]()
Thank you for downloading Hestia Control Panel! In a few moments,
we will begin installing the following components on your server:
- NGINX Web / Proxy Server
- Multi-PHP Environment
- Vsftpd FTP Server
- Firewall (iptables) + Fail2Ban Access Monitor
Installation backup directory: /root/hst_install_backups/210620240959
Installation log file: /root/hst_install_backups/hst_install-210620240959.log
[ * ] NGINX
[ * ] PHP
[ * ] Hestia Control Panel
Updating currently installed packages, please wait...|
NOTE: This process may take 10 to 15 minutes to complete, please wait...
Extracting templates from packages: 100%
[ * ] Configuring system settings...
[ * ] Configuring Hestia Control Panel...
[ * ] Configuring OpenSSL to improve TLS performance...
[ * ] Generating default self-signed SSL certificate...
[ * ] Adding SSL certificate to Hestia Control Panel...
[ * ] Enabling SFTP jail...
[ * ] Creating default admin account...
Log:
Creating config file /etc/php/8.2/mods-available/gd.ini with new version
Setting up rrdtool (1.7.2-3ubuntu6) ...
Setting up libc-devtools (2.35-0ubuntu3.8) ...
Setting up imagemagick (8:6.9.11.60+dfsg-1.3ubuntu0.22.04.3) ...
Processing triggers for libc-bin (2.35-0ubuntu3.8) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for install-info (6.8-4build1) ...
Processing triggers for php8.2-cli (8.2.20-2+ubuntu22.04.1+deb.sury.org+1) ...
Processing triggers for dictionaries-common (1.28.14) ...
aspell-autobuildhash: processing: en [en-common].
aspell-autobuildhash: processing: en [en-variant_0].
aspell-autobuildhash: processing: en [en-variant_1].
aspell-autobuildhash: processing: en [en-variant_2].
aspell-autobuildhash: processing: en [en-w_accents-only].
aspell-autobuildhash: processing: en [en-wo_accents-only].
aspell-autobuildhash: processing: en [en_AU-variant_0].
aspell-autobuildhash: processing: en [en_AU-variant_1].
aspell-autobuildhash: processing: en [en_AU-w_accents-only].
aspell-autobuildhash: processing: en [en_AU-wo_accents-only].
aspell-autobuildhash: processing: en [en_CA-variant_0].
aspell-autobuildhash: processing: en [en_CA-variant_1].
aspell-autobuildhash: processing: en [en_CA-w_accents-only].
aspell-autobuildhash: processing: en [en_CA-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-variant_0].
aspell-autobuildhash: processing: en [en_GB-variant_1].
aspell-autobuildhash: processing: en [en_US-w_accents-only].
aspell-autobuildhash: processing: en [en_US-wo_accents-only].
Processing triggers for php8.2-fpm (8.2.20-2+ubuntu22.04.1+deb.sury.org+1) ...
