I try install HestiaCP, but get error:
The following server components will be installed on your system:
- NGINX Web / Proxy Server
- Apache Web Server (as backend)
- Multi-PHP Environment
- Bind DNS Server
- Exim Mail Server
- Dovecot POP3/IMAP Server
- MariaDB Database Server
- PostgreSQL Database Server
- Vsftpd FTP Server
- Firewall (Iptables)
Installation backup directory: /root/hst_install_backups/140420202259
Installation log file: /root/hst_install_backups/hst_install-140420202259.log
(*) NGINX
(*) PHP
(*) MariaDB
(*) Hestia Control Panel
(*) PostgreSQL
Updating currently installed packages, please wait.../
Now installing Hestia Control Panel and all required dependencies.
NOTE: This process may take 10 to 15 minutes to complete, please wait... /
(*) Configuring system settings...
(*) Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/firewall': No such file or directory
(*) Generating default self-signed SSL certificate...
hst-install-ubuntu.sh: line 1078: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
(*) Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
(*) Configuring NGINX...
cp: cannot stat '/usr/local/hestia/install/deb/nginx/nginx.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/status.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/phpmyadmin.inc': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/phppgadmin.inc': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/nginx': No such file or directory
sed: can't read /etc/nginx/nginx.conf: No such file or directory
sed: can't read /usr/local/hestia/nginx/conf/nginx.conf: No such file or directory
Failed to start nginx.service: Unit nginx.service not found.
Error: nginx start failed
My steps:
- wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh
- sudo bash hst-install.sh -f -y no -e *** -p *** -s *** -o yes -g yes -t no -b no -r 8383 -l ru
I see that I do not have files to install, but where can I get them? what should I do? I apologize for my English. Please, help.
