zach
March 9, 2024, 11:01am
1
Hi, I’m installing Hestia and I’m on Ubuntu 22.
After running the second command, installation stuck there.
It says “The process may take 10 to 15 minutes…”, but it never proceeds, I have waited here for 40 minutes, but…
I used Filezilla to see what was installed, and found some file related with Hestia already installed.
But the problem is that it didn’t proceed…
Thanks!
Seems it is stuck here:
apt-get -y install $software > $LOG
Take a look to the log just in case you can see more info. The log should be here (ReplaceWithTheDate should be the date and time of the installation):
/root/hst_install_backups/hst_install-ReplaceWitTheDate.log
zach
March 9, 2024, 11:32am
3
Thanks!
Do you mean that I should run the command apt-get -y install $software > $LOG?
It is stuck there, I cannot input anything.
No, I don’t mean that, don’t execute that command manually, just check the log.
