Installer fails, needs netplan on ubuntu 18.04
I am totally newbie and trying to install Hestia with following installer script:
bash hst-install.sh -a yes -w yes -t yes -c no -x yes -b yes -i yes -m yes -l fi \ -s mycompany.tld [email protected] - MyPassword! -a yes -k yes -o yes
I get following error:
(*) Installing ntpdate…
WARNING: Your network configuration may not be set up correctly.
Details: The netplan configuration directory is empty.
You may have a network configuration file that was created using
systemd-networkd.
It is strongly recommended to migrate to netplan, which is now the
default network configuration system in newer releases of Ubuntu.
While you can leave your configuration as-is, please note that you
will not be able to use additional IPs properly.
If you wish to continue and force the installation,
run this script with -f option:
Example: bash hst-install-ubuntu.sh --force
Any help would be greatly appreciated.
Hello viperzero
Firstly your installer command looks incomplete, try this:
bash hst-install.sh -a yes -t yes -c no -x yes -b yes -i yes -m yes -l fi -s mycompany.tld -e [email protected] -p “MyPassword!” -k yes -o yes
Secondly, did you remove netplan from ubuntu? if you did, also remove /etc/netplan folder so that hestia would know which network config to use.
Hi, Lupu
thank you I did not disable netplan but seems that the default vps image don’t use netplan. I used the renaming netplan folder and corrected errors and hestia installed fine. Thank you.
thanks buddy
I faced same problem whn tried to install Hestia last version over Ubuntu 20.04 LTE
I solved this way:
sudo apt remove --purge netplan.io -y
then run the Hestia installer again.
