Installer password generation issue
The most annoying thing is that such a password cannot be changed using Hestia cli.
root@srv1:/# v-change-user-password admin EBMdNqX8
sed: -e expression #1, char 1: unknown command: `B'
I used this installer fix, but it didn’t help, I got wrong admin and database root passwords during installation (with default en_US locale). The password still contained characters that are not listed in the expression [A-Za-z0-9].
If the admin password can be changed by deleting mentions in the hestia config, then there are more serious problems with the database user, that is not so easy to fix.
Tested in Ubuntu 18.04 and 20.04
I have a guess. Since the described issue is observed only in the installer, but not in the system itself, can the installer file have the wrong encoding?
I just tried this on the system many times and got the following results:
root@srv1:/# cat /dev/urandom | tr -dc [A-Za-z0-9] | head -c16
eYRyZXVmzuYJChvu
Ou8FgtdqmzDFMexn
tiIZqPGZuRngO10L
jd][stRHPfKCo4p5
Configures that 1) there are practically no numbers in the generated passwords, 2) there are extra characters in the generated passwords, for example, ā€œ]ā€ and ā€œ[ā€ - see the last result
Correct syntax is:
head /dev/urandom | tr -dc A-Za-z0-9 | head -c 16
Source: How to generate a random string
Thanks @ram108, I’ll review the suggested code change, prepare a patch and we should be able to ship the fix together with the next feature release.
Fixed with https://github.com/hestiacp/hestiacp/pull/1191/commits/75e2c2750fc37479432829fd549628529bd8afba
Thanks for your contribution @ram108!
@ram108 can you join our discord server so we can communicate more quickly?
https://forum.hestiacp.com/t/join-our-official-discord-channel/1600
@ram108 I also started investigating, but even though I ran your script to change the locale and such, I wasn’t able to reproduce the issue.
could you elaborate on the system you are running? is it kvm or lxc or something else? are you using a template for installing your OS, if so which provider are you using?
i have exactly the same error. is it possible to fix it by installing the filemanager?
v-add-sys-filemanager
the bug is definitely new and probably came with version 1.2.2 or 1.2.3.
There is een bug how ever fixed in new version
At work, I have to install from time to time system on VPS. Each time these are new providers, always KVM and Ubuntu 18.04 or 20.04. And out of the last five to six installations, three or four times I have had the password issue.
At first I thought it was a matter of the locale, which I installed before installing Hestia, so I didn’t change the locale during the last installs. And yet got this issue again.
But I have not tried the last fix yet, I’m sure it fixes the problem.
thanks, when will the next version be released?
Probaly within 1-2 weeks, depending on the current testing.
