Installing ClamAV after installation
Is there any way to install clamav and the hestiacp plugin for it after the panel has been installed?
Can I just run the same exact command i used to install hestia the first time but with --clamav yes or will that mess with user accounts/data
Yes may be opting NO for all and YES for ClamAV as below may work but please wait for some experts suggestion as it might mess up some settings.
no, strongly not suggest to do it that way - the install script is only there to trigger it once.
Currently the only way is to follow the related clamav parts parts manualy - but only if you know what you’re doing. Otherwise you’ll be faster with backup users, reinstall the server and restore it.
Yes thats what I ended up doing actually. Thank you.
