Intall php extension
Hello I installed GMP extension with this command
sudo apt-get install php7.4-gmp
and I got this:
NOTICE: Not enabling PHP 7.4 FPM by default.
NOTICE: To enable PHP 7.4 FPM in Apache2 do:
NOTICE: a2enmod proxy_fcgi setenvif
NOTICE: a2enconf php7.4-fpm
NOTICE: You are seeing this message because you have apache2 package installed.
Processing triggers for php7.4-cli (7.4.14-1+ubuntu18.04.1+deb.sury.org+1) …
what should I do now
Nothing it could work fine…
<?php phpinfo();?> to check if the module is loaded
