dencha
July 14, 2024, 12:48pm
1
Hello, after installing hestia, creating domain, mails I can not login to roundcube with webmail.server.ip link. I`m getting this error:
# Oops... something went wrong!
For administrators: Please check the application and/or server error logs for more information.
I am only receiving mails, and cant send them, they just doesnt arrive. Btw I can login from roundcube.server link.
Port 25 is open:
root@sls7:~# telnet ASPMX.L.GOOGLE.COM 25
Trying 2a00:1450:4010:c0f::1aβ¦
Connected to ASPMX.l.google.com .
Escape character is β^]β.
220 mx.google.com ESMTP 2adb3069b0e04-52ed25719c1si887834e87.522 - gsmtp
Regarding roundcube, follow the steps in this post
Itβs a bug, execute these commands as root and try to access webmail again:
chown -R hestiamail:www-data /etc/roundcube/
find /etc/roundcube/ -type f -iname "*php" -exec chmod 640 {} \;
chown -R hestiamail:www-data /var/lib/roundcube/
chown -R hestiamail:www-data /var/log/roundcube/
If you will use phpmyadmin, execute these commands too:
chown -R root:www-data /etc/phpmyadmin/
chown -R hestiamail:www-data /usr/share/phpmyadmin/tmp/
Regarding not sending mails, you should check exim log /var/log/exim4/mainlog
dencha
July 14, 2024, 5:22pm
3
sahsanu:
Why they could be frozen?
root@sls7:~# tail /var/log/exim4/mainlog
2024-07-14 19:38:57 Start queue run: pid=20820
2024-07-14 19:38:57 1sSxvw-000Mbn-CB Message is frozen
2024-07-14 19:38:57 1sSy8A-0005l1-FP Message is frozen
2024-07-14 19:38:57 1sSy1Q-0001ek-27 Message is frozen
2024-07-14 19:38:57 End queue run: pid=20820
2024-07-14 20:08:57 Start queue run: pid=23692
2024-07-14 20:08:57 1sSxvw-000Mbn-CB Message is frozen
2024-07-14 20:08:57 1sSy8A-0005l1-FP Message is frozen
2024-07-14 20:08:57 1sSy1Q-0001ek-27 Message is frozen
2024-07-14 20:08:57 End queue run: pid=23692
You should view the complete log to know the reason.
exigrep 1sSy1Q-0001ek-27 /var/log/exim4/mainlog*
Or try to send a new mail and check the log.
dencha
July 14, 2024, 6:04pm
5
sahsanu:
Now after every email send try I see tls connection problem, is it bug too?
024-07-14 20:59:01 1sT3Uz-0004ZN-65 <= [email protected] H=localhost (webmail.domain.com) [127.0.0.1] P=esmtpa A=dovecot_login:[email protected] =531 [email protected]
2024-07-14 20:59:01 1sT3Uz-0004ZN-65 H=gmail-smtp-in.l.google.com [64.233.161.26] TLS error on connection (recv): The TLS connection was non-properly terminated.
2024-07-14 20:59:01 1sT3Uz-0004ZN-65 => [email protected] R=dnslookup T=remote_smtp H=gmail-smtp-in.l.google.com [64.233.161.26] X=TLS1.3:ECDHE_X25519__ECDSA_SECP256R1_SHA256__AES_256_GCM:256 CV=yes K C="250 2.0.0 OK 2adb3069b0e04-52ed252d200si890265e87.178 - gsmtp"
2024-07-14 20:59:01 1sT3Uz-0004ZN-65 Completed
You can ignore that TLS error message, it is because the way gmail closes the connection. Anyway, that message was delivered correctly to gmail.
dencha
July 14, 2024, 6:10pm
7
Thank you so much, Roundcub fix worked too. Now I`ve tried to send to my email and saw it went so SPAM folder, gonna try to fix that. You saved me
You are welcome
You should double check that you have the right spf and dmarc records for your domain, also, activate dkim and create the right records for it-
dencha
July 14, 2024, 6:37pm
9
Gonna check that, thanks!
system
Closed
August 13, 2024, 6:38pm
10
