IP address instead of hestia subdomain visible
I just recently upgraded my server (backup + move everything on a bigger server spec),
and since then I no longer see my hestiaCP custom subdomain,
but an IP address (which is not my real IP address);
in the CLI (user@ip-address), but also in the hestiaCP browser-window tab.
Is there something I must do, to get that custom subdomain back to be displayed?
[btw, of course I pointed my old static IP address onto the new server]
Thank you
Hi @AndyHestia,
Could you please give more details? I don’t know what you mean with custom subdomain and that you see an ip address… are you talking about the server’s hostname, was that subdomain assigned to a user in your old server?
No idea what you mean.
Hey,
yes, I mean the custom server hostname.
When logging into linux, I always saw: user@customhost,
now its user@IP-address.
Same goes for the hestiaCP; in the window tab I see:
WEB - ip-(address) - Hestia Control Panel
instead of
WEB - customhost - Hestia Control Panel
All since I upgraded the server.
Seems you need to change the server’s hostname.
v-change-sys-hostname your.custom.domain
And you should also get a certificate to it:
v-add-letsencrypt-host
Thanks.
However, I am still able to enter hestiaCP via web url (hostname.domain.com:port)
So actually that hostname is intact; it just doesn’t get shown in CLI as before.
Is it really needed to change that hostname because of that?
[I initially asked out of security concerns; if there is none, I would keep it as is].
Thanks.
Because one of users already had it assigned so it is normal that you can access using it.
v-search-object your.custom.domain
hostnamectl hostname
openssl x509 -in /usr/local/hestia/ssl/certificate.crt -noout -issuer -subject -dates
shows:
1st
shows the IP-address
shows:
Yes, I should mention that I am not using letsencrypt but cloudflare certificate.
Ok, then you only need to change the hostname:
Thanks, got it.
