Hello all,
In the hestia webinterface, ip banlist (@ url :8083/list/firewall/banlist/) I have a few ips listed under the service ‘recidive’ that are probably there because fail2ban found them in the past.
I also have added a few ip’s manually under the service ‘web’.
It seems that, after a reboot of the server, the chain ‘recidive’ is still filled with the banned ips (which is good), but the chain ‘web’ is empty (not good). Both checked with ‘iptables -L’.
Only after a manually ‘v-update-firewall’ the chain ‘web’ is as expected, filled with the ips from the banlist.
Is this intended behavior or a bug?
Thank you.
