Soon after I clear banned IP list a few hours later my IP goes back to the banned list so I am always blocked from all websites hosted by hestia. Anyway to stop this from happening?
You should figure out why fail2ban is repeatedly triggering a firewall rule to block your ip.
For now, you could add your ip to the whitelist in /etc/fail2ban/jail.d/whitelist.local so fail2ban will ignore it.
❯ cat /etc/fail2ban/jail.d/whitelist.local
[DEFAULT]
ignoreip = here.your.ip
Restart Fail2Ban to apply the change.
systemctl restart fail2ban
whitelist.local is not in my jail.d folder it is empty
You must create it and add the content.
OK and what if I want to add an IP range like for example all IPs on 204.152.xxx.xxx
[DEFAULT]
ignoreip = 204.152.0.0/16
OK done. Now I will monitor to see if it works. Much thanks for your help.
Didn’t work. My IP is back in the banned list ![]()
Show the output of:
Did you restart fail2ban?
Screenshot by Lightshot I am unable to do so. This remains off even when I restart
cat -A /etc/fail2ban/jail.d/whitelist.local
systemctl status fail2ban --no-pager -l
