IP Witelist for a web domain
Hi. let’s say I have a website: example.com which, for security reasons, I only want to allow access to a small handful of people. They’ll give me their public IP addresses and I’ll add them to a white list.
Can anyone advise if there’s a wayto do this in Hestia? Maybe there’s a way to do this int he DNS records? All my research points to blacklisting some IP addresses on the server’s firewall, I not only want to create a whitelist (not a black list) but I want it only for one domain/DNS zone on the server, not the entire server.
Many thanks
.htaccess allow deny from ip. For examples please refer to google.
Didn’t know .htaccess could be used to do things like that. Thanks, I’ll give it a try
Great, it worked. Thanks for the help. I inserted the following to my .htaccess file:
#Start Whitelist
order deny,allow
deny from all
allow from 111.111.111.111
#End Whitelist
Hi, just quick question, I’m not expert, but how this can be done on Hestia CP using Nginx only ? I found I can set allow some IP and later place a deny all; on /etc/nginx/nginx.conf, but this is applied to all websites, how can be done on only one of the sites ?
Let’s say your user is test and your domain is example.net, and you allow access to this site only to ips 203.0.113.1 and 192.0.2.1
Create a conf file like nginx.conf_whatever, in this case, we will use nginx.conf_access and this file must be in this dir:
/home/test/conf/web/example.net/
The contents of file nginx.conf_access:
allow 203.0.113.1;
allow 192.0.2.1;
deny all;
If you are using ssl, create also a conf file nginx.ssl.conf_access but there is no need to create it from scratch, just create a symbolic link:
cd /home/test/conf/web/example.net/
ln -rs nginx.conf_access nginx.ssl.conf_access
Now reload nginx:
systemctl reload nginx
Dear Sahsanu, you rock, thanks a lot, I really appreciate it :slight_smile: it worked, I was actually trying to edit nginx.conf file on /home/user/conf/web/example.net/.
I have to say in my 2 production VPS I’m using hestiacp, have test a lot of free options to leave my old shared reseller cPanel hosting soon and I simple love HestiaCP, hope I can contribute with some money soon :smiley:
