Hi everyone.
I want to ask you a question about wordpress on a server with hestia.
Apparently everything seems to work fine except for the WP-super-cache plugins and a BulletProof Security WordPress security plugin.
These generate an error and it seems that they make requests for port 80 and 443 to some API.
There is some configuration in hestia’s iptables to block API requests through the port. 80/443???
I can’t find guidance, I’ve looked a lot on the net without success and I have to ask here.
Hello, I have not formulated my question well.
I have created a new server with hestia, I have installed wordpress again and the error persists with some plugins.
Of the kind:
cURL error 7: Failed to connect to domain .com port 80: Connection refused
cURL error 7: Failed to connect to domain .com port 443: Connection refused
Other:
Apache Modules|Directives|Backward Compatibility(Yes|No)|IfModule(Yes|No):
ERROR: wp_remote_get() function is blocked or unable to get the URL path
: mod_access_compat is not Loaded|IfModule: Yes
: mod_authz_core is not Loaded|IfModule: Yes
: mod_authz_host is not Loaded|IfModule: Yes
: mod_rewrite Inconclusive: Status is not 200, 301, 302, 403 or 404
: mod_security Module is not Loaded|Enabled|IfModule: Yes
