Hello, how can I debug the reason that iptables won’t start after upgrade to 1.4.3?
this is related to my installation, I have an other installation and iptables run ok
thanks!
thanks!
same problem.
Run
cat /usr/lib/networkd-dispatcher/routable.d/10-hestia-iptables
It should show something like:
#!/bin/sh
if [ “$IFACE” = “eno3” ]; then
[ -x “/sbin/ipset” ] && /usr/local/hestia/bin/v-update-firewall-ipset
/sbin/iptables-restore < /etc/iptables.rules
fi
exit 0
eno3 = is in this case the ethernet port
Check if that is the correct and active ethernet port
the directory
/usr/lib/networkd-dispatcher is not present al all.
Also/etc/networkd-dispatcher does not exist
what does it mean?
You are using netplan?
yes, even on an other hestia installation where iptables works and /usr/lib/networkd-dispatcher/routable.d/10-hestia-iptables exists with content
#!/bin/sh
if [ “$IFACE” = “ens160” ]; then
[ -x “/usr/sbin/ipset” ] && /usr/local/hestia/bin/v-update-firewall-ipset
fi
exit 0
yes installed
networkd-dispatcher is already the newest version (2.0.1-1).
Hi, any other idea to solve the issue?
Is the server using Netplan or systemd for the network configuration?
installation is a default ubuntu 20.04, I set the IP address in /etc/netplan
how to get the right answer for you? thanks!
You might need to try this
it seems that running v-stop-firewall 1 time, then starting service from hestia panel worked!
