Is apparmor Debian somehow related to Hestia 1.9.2
Hi all, today I installed Hestia 1.9.2 on Debian 12, everything is fine, only
apparmor.service loaded failed failed Load AppArmor profiles
didn’t help
sudo mv /etc/apparmor.d/bwrap-userns-restrict /etc/apparmor.d/bwrap-userns-restrict.backup
The error is that the profile can not start, because there is no directory
ls -l /etc/apparmor.d/abi/4.0
and the syntax error on line 27 is this allow pix /** → &bwrap//&unpriv_bwrap,
/etc/apparmor.d/disable/bwrap-userns-restrict
# This profile allows almost everything and only exists to allow bwrap
# to work on a system with user namespace restrictions being enforced.
# bwrap is allowed access to user namespaces and capabilities within
# the user namespace, but its children do not have capabilities,
# blocking bwrap from being able to be used to arbitrarily by-pass the
# user namespace restrictions.
# Note: the bwrap child is stacked against the bwrap profile due to
# bwraps use of no-new-privs.
abi <abi/4.0>,
include <tunables/global>
profile bwrap /usr/bin/bwrap flags=(attach_disconnected,mediate_deleted) {
  allow capability,
  # not allow all, to allow for pix stack on systems that don't support
  # rule priority.
  # sadly we have to allow 'm' every where to allow children to work under
  # profile stacking atm.
  allow file rwlkm /{**,},
  allow network,
  allow unix,
  allow ptrace,
  allow signal,
  allow mqueue,
  allow io_uring,
  allow userns,
  allow mount,
  allow umount,
  allow pivot_root,
  allow dbus,
  # stacked like this due to no-new-privs restriction
  # this will stack a target profile against bwrap and unpriv_bwrap
  # Ideally
  # - there would be a transition at userns creation first. This would allow
  #   for the bwrap profile to be tighter, and looser within the user
  #   ns. bwrap will still have to fairly loose until a transition at
  #   namespacing in general (not just user ns) is available.
  # - there would be an independent second target as fallback
  #   This would allow for select target profiles to be used, and not
  #   necessarily stack the unpriv_bwrap in cases where this is desired
  # the ix works here because stack will apply to ix fallback
  # Ideally we would sanitize the environment across a privilege boundry
  # (leaving bwarp into application) but flatpak etc use environment glibc
  # sanitized environment variables as part of the sandbox setup.
#  allow pix /** -> &bwrap//&unpriv_bwrap,
  # the local include should not be used without understanding the userns
  # restriction.
  # Site-specific additions and overrides. See local/README for details.
  include if exists <local/bwrap-userns-restrict>
# The unpriv_bwrap profile is used to strip capabilities within the userns
profile unpriv_bwrap flags=(attach_disconnected,mediate_deleted) {
  allow network,
  allow unix,
  allow ptrace,
  allow signal,
  allow mqueue,
  allow io_uring,
  allow userns,
  allow mount,
  allow umount,
  allow pivot_root,
  allow dbus,
  # bwrap profile does stacking against itself this will keep the target
  # profile from having elevated privileges in the container.
  # If done recursively the stack will remove any duplicate
  allow pix /** -> &unpriv_bwrap,
  audit deny capability,
  # restriction.
  include if exists <local/unpriv_bwrap>
Now, after commenting out line 27, the service is running, the question is, does it even affect Hestia?, before that, how many did I put such difficulties? Thanks
The file is to make sure that apparmour configuration for the bubblewrap container is using the right persmissions. It’s mostly mean to avoid issues on Ubuntu 24.04.
We also installed it on Debian to add the same restrictions to bubblewrap. But changing the file should not impact the inner working or the bubblewrap containers so you’re good.
Thank you, as I see in the new DEbian installation there is apparmour, but the file /etc/apparmor. d/disable/bwrap-userns-restrict, as I understand it was created by Hestia, but then it may be worth fixing syntax error on line 27 is this allow pix / * * → &bwrap//&unpriv_bwrap ? Or is there something I don’t understand? If this remains, then every installation will be accompanied by an error starting apparmour, right?
The file is mostly meant to fix issues introduced by abi4.0 (Ubuntu 24.04). For your case you can safely remove the file without causing any issues for the bubblewrap jail.
I made a fix to avoid installing the the file if abi 4.0 is not installed:
