I’m setting up a server with Hestia and using cf for DNS. Is it necessary to enable DNS in Hestia? Also, Hestia automatically creates NS records—could this cause any issues with cf? How can I completely disable DNS and NS in Hestia CP?
TIA
K
TIA
K
The best way is to simply not install the DNS option.
What about NS ?
You will use Cloudflare as name servers…
I already using cf ns. My ques is how can i completely stop and or disable the default ns in hestia at the beginning. as the ns and dns is not needed for my use case.
The answer is still the same as earlier.
