Is it possible to add another website in the panel?
Hi, I have an Oracle free server and I currently have a very small website. I have plenty of space and power. Could I add another domain and install WordPress?
Of course in the panel I see the “Add web domain” button but I don’t know if it is possible with the only IP of the server and if it is possible I don’t know the steps.
Regards,
John
Yes you can
So following these steps should not affect my current domain, right? Both would continue to function separately without conflict.
Yes dude dont be afraid you can host as many websites your server resources can. The ip is just a number for the world to communicate with your websites!
Thank you, I will practice this week.
Hi, I followed the instructions and created another user to separate the sites. When I add the new domain, I don’t see any changes. It does not work when I want to enter the site
I already changed the DNS in Cloudflare and nothing… the other site using the same IP continues to work perfectly.
Any idea?
You have a wrong redirection in Cloudflare that is looping once and again.
curl -IkL designxcreativity.com
HTTP/1.1 301 Moved Permanently
Date: Sun, 03 Dec 2023 09:12:42 GMT
Connection: keep-alive
Cache-Control: max-age=3600
Expires: Sun, 03 Dec 2023 10:12:42 GMT
Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=6mOGNtUv3vNiHfKm0lxlxdYMfjdfzJ1hJWwm5JXrRtVHyOV0gJdY0yPoxu2O4Caumz7E2TtTomzWAkQwarglaF%2BD4EcFLItlFnXFttaymeC85TA86jQWmHyXKx2xxSFfAdQU4%2F78LPU%3D"}],"group":"cf-nel","max_age":604800}
NEL: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
Server: cloudflare
CF-RAY: 82fab07e9a6b4d85-FRA
alt-svc: h3=":443"; ma=86400
HTTP/2 301
date: Sun, 03 Dec 2023 09:12:42 GMT
content-type: text/html
cf-cache-status: DYNAMIC
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=oSDeEFr92gS4FFpTaAn8SOkWUgpp5hWdkCD75jBHJJKlFdaOlJR9DFvkt4qYx9QUNPtaUWkI6YCcarl47zIQKYdG59ykFraI0kKwHyvvNHJZnrw8DMGyqQglpTXiJW5HKU%2FEQh9kojQ%3D"}],"group":"cf-nel","max_age":604800}
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 82fab07ef8c50a68-AMS
HTTP/2 301
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=lYZ27KeECQ4VkxREnAOrYGzmyh4t6Si%2F4ynFr7GNez4KO3sdeZ92f9O1BS0U4%2Bkb7EsWGbWvNZ4QdjYwYuBumpC4mrcrYcrNABqHD4%2F5OYYpuWfxrwuWO2EwSsuyiBQ2xxo%2B5UJiHu0%3D"}],"group":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 82fab0803a1b0a68-AMS
[...] <- here more redirections
HTTP/2 301
date: Sun, 03 Dec 2023 09:12:47 GMT
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=xbgfyHHT344IG4DDVHOJXlee6z%2BAuurAR7DDtgQ8oUZwlr5g%2Fs5VW2knjVoIZlT9BAq0gdqW1OcdCrrFrqI3EtUuU6eN18gD2w%2BfXmNpZXKYoYCqLazemxwQfu9oO5GiZfW9%2F3ALXac%3D"}],"group":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 82fab0a09fba0a68-AMS
curl: (47) Maximum (50) redirects followed
If trying to connect directly using the actual server’s ip, it works fine:
curl -IkL --resolve "*:80:158.101.114.60"  --resolve "*:443:158.101.114.60" designxcreativity.com
Server: nginx
Date: Sun, 03 Dec 2023 09:16:48 GMT
Content-Type: text/html
Content-Length: 162
HTTP/2 200
server: nginx
date: Sun, 03 Dec 2023 09:16:48 GMT
content-type: text/html; charset=UTF-8
vary: Accept-Encoding
link: <https://designxcreativity.com/index.php?rest_route=/>; rel="https://api.w.org/"
And the Cloudflare’s cert is installed correctly in your Hestia server for your domain:
echo | openssl s_client -connect 158.101.114.60:443 -servername designxcreativity.com 2>/dev/null | openssl x509 -noout -dates -issuer -ext subjectAltName
notBefore=Dec  3 07:55:00 2023 GMT
notAfter=Nov 29 07:55:00 2038 GMT
issuer=C = US, O = "CloudFlare, Inc.", OU = CloudFlare Origin SSL Certificate Authority, L = San Francisco, ST = California
X509v3 Subject Alternative Name:
    DNS:*.designxcreativity.com, DNS:designxcreativity.com
So, you should recheck how you configured the domain in Cloudflare because it is looping and not trying to reach your Hestia server.
Option 1: Login into Cloudflare
Then request ssl via Hestia Lets encrypt and when don enable Strict or full
Option 2
SSL Certificates | Hestia Control Panel and set to full directly
I don’t know why Cloudlfare sets it default to “Flexible” anyways … time to change
I think it is fixed. I went to Cloudflare and selected in SSL/TLS encryption the Full option and it automatically started working. Do you notice the same thing?
I think the SSL is working correctly now and the web.
Yes, it is working fine now.
Perfect. So is it correct that I have created different users for each website? I have two sites with the same IP.
Yes, it’s correct, I mean, it’s also correct to have only one user (as long as it is not admin to avoid security issues).
Perfect. Thank you very much for all the help.
