I’m new to Hestia and everything is going smoothly except for setting up SSL. Since I rely on Cloudflare, I need to install Cloudflare SSL in Hestia. I’ve checked a lot of online threads about this issue, but most of them are outdated and none have worked for me so far.
Is there anyone who has successfully set up Cloudflare SSL in Hestia recently? Could you please share the steps or any updated resources that might help?
When you say use Cloudflare SSL, are you asking about the use of a Cloudflare Origin CA certificate on your HestiaCP server? You should be able to use one. Direct connections that do not route through the Cloudflare proxy should show an unknown issuer warning since the Cloudflare Origin CA is only trusted by the Cloudflare proxy.
