Fiuxy
1
How do I increase the upload? I need to mount a 3.85 GB file and it couldn’t
It tells me this: is too large, plase upload files less than 1 GB
eris
2
You can try to update the upload limit…
But config files get overwritten during updates of FM…
Or use scp / sftp / ftp
I tried to edit the limit in the past and it was a lot of trouble. It simply won’t work in the long run.
Use SCP. WinSCP is a great tool for that.
sku
4
I think, you need make changes in one more place - hestia php-fpm – /usr/local/hestia/php/etc/php-fpm.conf
php_admin_value[post_max_size] = 256M
php_admin_value[upload_max_filesize] = 256M
php_admin_value[max_execution_time] = 300
php_admin_value[max_input_time] = 300
(don’t forget to reload hestia services after)
system
Closed
5
