[ISSUE] HestiaCP behind Cloudflare Zero Trust tunnel
I already have some services exposed using CF ZeroTrust tunnel, and all of them works well. Except for HestiaCP.
I already changed the HestiaCP port from 8083 to 2083, being one of the supported ports by CF using HTTPS protocol. Created the tunnel and so on.
But, after trying to connect to the domain (subdomain) and passing the corresponding authentication method, it just doesn’t load the HestiaCP WebUI, and tells that the Host (HestiaCP) is not available.
Is someone using CF to access HestiaCP? How did you configure it?
