Greetings,
Storj increased their minimum spend by 10x, and I decided to take a look at Backblaze for doing incremental backups. I was able to rclone all restic repos over on the test box, and the existing accounts work fine.
When I create a new user, the system tries to run a backup - it sees there is no restic.conf file (containing the restic password for that user), and it attempts to initialize. I get a message saying:
rclone: 2026/06/03 12:11:12 ERROR : : Create repo failed to Mkdir: operation error S3: CreateBucket, https response error StatusCode: 403, RequestID: xxx, HostID: xxx, api error AccessDenied: not entitled
Fatal: create repository at rclone:backblaze:/some.domain.com/someuser failed: server response unexpected: 500 Internal Server Error (500)
Once it errors here, it then creates the restic.conf file and subsequent runs complains :
Fatal: unable to open config file: does not exist
Is there a repository at the following location?
It appears like Backblaze does not let you create a directory, you are supposed to just reference it and it will work. Here is why I say that:
#rclone mkdir backblaze:/some.domain.com/test2 2026/06/03 12:23:09 NOTICE: S3 bucket some.domain.com path test2: Warning: running mkdir on a remote which can’t have empty directories does nothing 2026/06/03 12:23:09 ERROR : Attempt 1/3 failed with 1 errors and: operation error S3: CreateBucket, https response error StatusCode: 403, RequestID: xxx, HostID: xxx, api error AccessDenied: not entitled 2026/06/03 12:23:09 ERROR : Attempt 2/3 failed with 1 errors and: operation error S3: CreateBucket, https response error StatusCode: 403, RequestID: xxx, HostID: xxx, api error AccessDenied: not entitled 2026/06/03 12:23:09 ERROR : Attempt 3/3 failed with 1 errors and: operation error S3: CreateBucket, https response error StatusCode: 403, RequestID: xxx, HostID: xxx, api error AccessDenied: not entitled 2026/06/03 12:23:09 NOTICE: Failed to mkdir: operation error S3: CreateBucket, https response error StatusCode: 403, RequestID: xxx, HostID: xxx, api error AccessDenied: not entitled
Anyone here had any experience with this or what maybe to look at? I searched through the hestia/bin folder for anything rclone and mkdir and find nothing, so not sure whats trying to make the directory.
Thanks,
