Since migrating to hestia from vesta, I have noticed that the labels of the messages I make from thunderbird disappear when moving the message from one folder to another. I still have a server with vestacp and the tags are not removed on that
How can I configure dovecot to keep the labels of the messages that I have put from thunderbird? It’s very important !
I have tried several options that you indicate in your link but they do not work, in each test I have restarted the entire server and it remains the same
It’s not the thunderbird’s fault but the Dovecot. something needs to be turned on or off for it to work
Please help!
In archive dovecot.conf i have included this line that seems like it should work but it doesn’t work
I have tried many combinations but I think I am going astray:
mbox_read_locks = flock
mbox_write_locks = flock
mbox_dirty_syncs = no
mbox_lazy_writes = no
I think this is not good for maildir, I need you to help me please!
I have found the solution! the problem is debian! has a version with a bug in version dovecot-core 2.3.4.1-5!!! the correct version is dovecot_2.3.13.
I do not know if from hestiacp this error can be officially solved that I shouldn’t know when it will take to solve it!
to correct you have to do this:
Create /etc/apt/trusted.gpg.d/dovecot.gpg
curl https://repo.dovecot.org/DOVECOT-REPO-GPG | gpg --import
gpg --export ED409DA1> /etc/apt/trusted.gpg.d/dovecot.gpg
Create /etc/apt/sources.list.d/dovecot.list. If you want to use https, make sure you have installed apt-transport-https.
deb https://repo.dovecot.org/ce-2.3-latest/debian/buster buster main
Instructions
If you are upgrading from existing installation, run
apt update
apt upgrade
I just wanted to know if it is advisable to put that extra dovecot repo to update or is it better to wait until they should put this update in the official repo? It is a server in production and cannot fail!
thanks for your quick response!
Yes, update without problems and it is working well at the moment, the question is: do I leave this official dovecot repo active or do I deactivate it and wait for debian 10 to put it in its official repo?
I do not know if Debian 10 will update to that version, in Debian 11 I have seen what they have in their repo.
