It is not possible to install Hestia 1.9
I install it now as standard on ubuntu 24.04, I get
wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh && sudo bash hst-install.sh --apache no --phpfpm yes --multiphp no --vsftpd no --proftpd no --named no --mysql yes --mysql-classic no --postgresql no --exim yes --dovecot yes --sieve no --clamav no --spamassassin yes --iptables yes --fail2ban yes --quota no --api no --interactive yes --with-debs no  --port '2083' --hostname 'hestia.angellive.ru' --email '[email protected]' --password 'pasvord' --lang 'ru' --force
[ * ] Configuring system settings...
info: Adding user `hestiamail' to group `hestia-users' ...
[ * ] Configuring Hestia Control Panel...
[ * ] Configuring OpenSSL to improve TLS performance...
[ * ] Generating default self-signed SSL certificate...
[ * ] Adding SSL certificate to Hestia Control Panel...
[ * ] Enabling SFTP jail...
[ * ] Enabling SSH jail...
[ * ] Creating default admin account...
[ * ] Configuring NGINX...
[ * ] Updating Cloudflare IP Ranges for Nginx...
[ * ] Installing PHP 8.3...
[ * ] Configuring PHP-FPM 8.3...
Job for php8.3-fpm.service failed because the control process exited with error code.
See "systemctl status php8.3-fpm.service" and "journalctl -xeu php8.3-fpm.service" for details.
Error: php-fpm start failed
On the betta version, everything was installed well right there
*** System restart required ***
Last login: Tue Feb  4 21:24:07 2025 from 104.28.198.245
root@hestia:~# systemctl status php8.3-fpm.service
Ɨ php8.3-fpm.service - The PHP 8.3 FastCGI Process Manager
     Loaded: loaded (/usr/lib/systemd/system/php8.3-fpm.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Tue 2025-02-04 21:31:43 UTC; 10min ago
       Docs: man:php-fpm8.3(8)
    Process: 39482 ExecStart=/usr/sbin/php-fpm8.3 --nodaemonize --fpm-config /etc/php/8.3/fpm/php-fpm.conf (code=exited, status=78)
    Process: 39484 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/8.3/fpm/pool.d/www.conf 83 (code=>
   Main PID: 39482 (code=exited, status=78)
        CPU: 59ms
фев 04 21:31:42 hestia.angellive.ru systemd[1]: Failed to start php8.3-fpm.service - The PHP 8.3 FastCGI Process Manager.
фев 04 21:31:43 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Scheduled restart job, restart counter is at 5.
фев 04 21:31:43 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Start request repeated too quickly.
фев 04 21:31:43 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Failed with result 'exit-code'.
фев 04 21:31:43 hestia.angellive.ru systemd[1]: Failed to start php8.3-fpm.service - The PHP 8.3 FastCGI Process Manager.
root@hestia:~# systemctl restart php8.3-fpm.service
ā–‘ā–‘
ā–‘ā–‘ An ExecStart= process belonging to unit php8.3-fpm.service has exited.
ā–‘ā–‘
ā–‘ā–‘ The process' exit code is 'exited' and its exit status is 78.
фев 04 21:43:09 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Failed with result 'exit-code'.
ā–‘ā–‘ Subject: Unit failed
ā–‘ā–‘ Defined-By: systemd
ā–‘ā–‘ Support: http://www.ubuntu.com/support
ā–‘ā–‘
ā–‘ā–‘ The unit php8.3-fpm.service has entered the 'failed' state with result 'exit-code'.
фев 04 21:43:09 hestia.angellive.ru systemd[1]: Failed to start php8.3-fpm.service - The PHP 8.3 FastCGI Process Manager.
ā–‘ā–‘ Subject: ŠžŃˆŠøŠ±ŠŗŠ° ŃŽŠ½ŠøŃ‚Š° php8.3-fpm.service
ā–‘ā–‘
ā–‘ā–‘ ŠŸŃ€Š¾ŠøŠ·Š¾ŃˆŠµŠ» сбой ŃŽŠ½ŠøŃ‚Š° php8.3-fpm.service.
ā–‘ā–‘
ā–‘ā–‘ Š ŠµŠ·ŃƒŠ»ŃŒŃ‚Š°Ń‚: failed.
фев 04 21:43:09 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Scheduled restart job, restart counter is at 5.
ā–‘ā–‘ Subject: Assigned to automatically restart the unit
ā–‘ā–‘
ā–‘ā–‘ An automatic restart of the php8.3-fpm.service unit is assigned, because it was set to
ā–‘ā–‘ параметр Restart=.
фев 04 21:43:09 hestia.angellive.ru systemd[1]: php8.3-fpm.service: Start request repeated too quickly.
ā–‘ā–‘
ā–‘ā–‘ Subject: php8.3-fpm.service unit error
ā–‘ā–‘
ā–‘ā–‘ The php8.3-fpm.service unit failed.
ā–‘ā–‘
OK I had PHP version 8.2 when I upgraded)
