Hello
After switching to bubblewrap via the script, I noticed an error in connecting to FTP 500 OOPS
I noticed that in the FTP config there was a parameter:
local_root=/srv/jail/%u
Because of which FTP did not work.
Replaced with - local_root=/home/%u/web
Please check and fix this in the migrate_jailkit_to_bubblewrap.sh script and also, if necessary, in the panel installer
I just reported an error.
vsftpd is installed
When creating an additional FTP user, a folder with the user appears in the /srv/jail directory.
But I switched to bubblewrap. When you create a new user, nothing is created for him.
Because of this, FTP stopped working correctly for me. Namely, additional FTP accounts do not work if you create
What should I do?
I come to the conclusion that when creating an additional user, ftp should not create a folder in /srv/jail/ in case of using bubblewrap
Dear developers, please provide an explanation.
I changed the parameter in VSFTPD to: local_root=/home/%u/web And it was local_root=/srv/jail/%u
I stopped all jails and deleted the folders /srv/jail. When switching to bubblewrap
Or did I do something wrong?
And when will this be fixed?
I dont know if it is considered as bug or even if it will be fixed, beside there is no eta.
This is an error
Additional FTP users do not work at all.
eris
June 5, 2025, 10:18pm
9
Jailkit was never offered in a final release. So I think the number of users affected are really low…
How can I set it up now so that additional FTP users work?
eXe
June 6, 2025, 7:48pm
12
If it is, i think there acually no support for this featue.
Is it possible to baypass this if it is not working ?
Please fix it so that additional ftp users work when using bubblewrap!
I temporarily solved the problem
Set allow_writeable_chroot=YES instead of allow_writeable_chroot=NO
Also commented out:
#local_root=/srv/jail/%u
#local_root=/home/%u/web
#user_sub_token=%u
mhbeyle
February 14, 2026, 10:22am
15
You can also combine ‘Set allow_writeable_chroot=YES’ and ‘local_root=/srv/jail/%u/home/%u’ (add ‘/home/%u’ additionally), if you still want to use the jail without the additional /home/[user] and accept a slight visual inconsistency between ftp and sftp (OpenSSH).
